low fuel pressure
Old Jun 16, 2006 | 09:42 PM
TAdriver's Avatar
Default low fuel pressure
I have a 97 Trans Am and my fuel pressure is 34psi with the key on engine off and 36psi at idle. With the vacuum line off of the regulator the pressure was at 42psi. I hooked up 12-14 inches of vacuum to the fuel pressure regulator like the hanes manual suggests and there was no change in the pressue. The manual says to replace the regulator if the pressure does not change. My fuel filter is new and I have 90,000 miles on the car. Does this sound like the problem is definitely in the regulator.
Old Jun 22, 2006 | 12:10 PM
silverado01's Avatar
I've got the same problem.
ttt
