Weird fuel Problem need help.
Old Jun 20, 2006 | 03:33 PM
1blackz28's Avatar
Default Weird fuel Problem need help.
So my car was cutting out intermitently the other day when it just shut down and would not fire back up. Checked for fuel at the valve on the fuel rail and no preasure what so ever. I can hear the pump prime so I figured that the pump is working and so im thinking filter. Well took the filter loose and fuel poured out but not like it was under preasure more like it was ciphoning out of the tank. So I tried an expirement and turned the key to the run position thinking that if the pump was ok it should shoot fuel out the other end of the filter but it just kept pouring out. I put a walboro 255 in about 2 years ago and replaced the filter at the same time. Any ideas.
Old Jun 20, 2006 | 05:56 PM
1blackz28's Avatar
Forgot to mention car is a 98
Old Jun 20, 2006 | 11:00 PM
1bad71's Avatar
sounds like it's bypassing internally in the tank! either the pump is weak or the feed hose from the pump has a small hole in it!
either way, time to drop the tank!!
Old Jun 21, 2006 | 01:02 AM
1blackz28's Avatar
Thanks for the reply. Even it it could produce some preasure i thought i would have seen it with a open feed line when i disconnected the fuel filter and primed it. No need to drop the tank i already have an access panel.
Old Jun 21, 2006 | 07:51 AM
1blackz28's Avatar
Oki think he is talking about the small hose that comes directly off the pump. Anyone elese got any ideas
Old Jun 21, 2006 | 11:23 AM
1blackz28's Avatar
TTT for the lunch crowd
Old Jun 21, 2006 | 08:00 PM
Trashed's Avatar
man im having the same problem, but i ordered the racetronix pump and a filter and some new ngk's. hopefully that will work.
Old Jun 21, 2006 | 11:59 PM
1bad71's Avatar
inside the fuel module unit there is a small hose that conects the pump to the pump module " usally clear plastic", it may have split or come off completly. hence! pump running but no pressure!!
if you have a access panel, then pull the pump out and put it in a coffee can of gas and jump it to see if theres a leak you can't see.
Old Jun 22, 2006 | 03:17 PM
1blackz28's Avatar
Thanks for the help guys the ruber hose was toast all better now
