are the stock injectors big enough for this setup?
Old Jun 18, 2006 | 04:15 AM
sfields's Avatar
Question stock injectors big enough????
just wondering if the stock injectors will be ok for the time being. I have a 383 stroker with AFR heads TR 224 114 LSA and a fast 90/90 set up and everyother bolt on. I'm in the process of putting it together now. I was told that stock injectors are good for about 450 rwhp> any help will be appreciated very much.
Old Jun 18, 2006 | 05:19 AM
EPP's Avatar
EPP
I'd jump up to 42lb injectors, as you're going to be close to maxing out the stock injectors. Bob
Old Jun 18, 2006 | 07:53 AM
ApacheDrill's Avatar
cheap insurance..upgrade
Old Jun 24, 2006 | 10:09 PM
dalejr8ls1's Avatar
42's would do the trick..I think some SVO 30's would hold up just fine for what you have. Why not go with a bigger cam for that setup??
Old Jun 28, 2006 | 06:31 PM
slow trap's Avatar
i would also say get some 42s,the 28.8 lbers may do it for awhile but i'm sure they would be over 100 %,you want to shoot for 80- 85 % or less.
Old Jun 28, 2006 | 10:45 PM
edgz06's Avatar
Let me tell you with 100% certainty that there is no way your stock injectors will flow enough fuel for that combo. A cam, long tubes and proper tune alone would max out your injectors, never mind a stroker motor with AFR heads.
I wouldn't even go with 42s, get 60# injectors and upgrade your fuel pump at the very least. 60s will give you room for more power down the road and they only run about $100 more than the 42s.
Oh, and running your stock injectors maxed out will cause consistent knock retard, not exactly what you want for a stroker motor you just invested in.
