Bosch 42# Injectors
Old Jun 19, 2006 | 11:10 AM
BADSZ28's Avatar
Default Bosch 42# Injectors
Do these come on anything from the factory? I am trying to buy a set and the only way they can look them up in through vehicle type. Is the correct PN 0280150558?
Old Jun 19, 2006 | 11:15 PM
Grimes's Avatar
Bosch 0280150558
Stock replacements for
Lightning Truck
Fitments: Modified/Supercharged V-8
and V-6 applications.
http://www.fiveomotorsport.com/Injector_SetsFORDTRK.asp
good luck
Old Jun 19, 2006 | 11:38 PM
CAT3's Avatar
Restricted User
So the FMS are actually Bosch Injectors? I have a set of lime green top 42# off a lightning and thought they are FMS/SVO not Bosch...separate or equal entities?
Old Jun 20, 2006 | 08:29 AM
BADSZ28's Avatar
Bosch makes them and others put their name on them.
Old Jun 23, 2006 | 07:41 PM
ls1z01's Avatar
Any disadvantage going with BOSCH 42#?
Old Jun 25, 2006 | 11:11 AM
x phantom x's Avatar
STF veteran / 10 second club
I would love to know this as well....
Old Jun 29, 2006 | 06:11 AM
See5's Avatar
I think the SVO series 30, 36 and 42 are great. Have used them all. The 42s run ~50# for us. Easy to tune.
Old Jun 29, 2006 | 07:29 PM
SmaknaSS's Avatar
Who has a good price for the Bosch 42's?
Old Jun 29, 2006 | 09:42 PM
RedHardSupra's Avatar
summit had them for like $25x i think. THE injector of choice for big cam or head/cam combos. too small however for any form of FI.
Old Jun 30, 2006 | 08:15 AM
BADSZ28's Avatar
What RWHP are they good to?
Old Jun 30, 2006 | 10:13 AM
usually 480-500rwhp, depending on rpm and application
Old Jun 30, 2006 | 10:37 AM
BADSZ28's Avatar
That may not be enough then. I thought they were good to 600. Back to the drawing board I guess.
Old Jun 30, 2006 | 10:41 AM
it's about 480-500 with a healthy margin. just use this and you'll see what you need:
http://redhardsupra.blogspot.com/200...readsheet.html
Old Jun 30, 2006 | 10:59 AM
BADSZ28's Avatar
Cool. I have that sheet, now I need to learn how to use it. Under the bigass cam line you have VE at 120%. At what kPa?
Old Jul 1, 2006 | 12:59 AM
well, the VE LS1's display is not really VE, it's VE at pressure and at temperature...so don't pay attention too much to the 120% number. basically go with 80 for stock, 100 for small mods, 120 for a fully done setup. i find it to be a very good heuristic.
the important inputs are in yellow. cylinders, displacement, max rpm, VE (use the heuristic i just mentioned), and boost. most NA cars can't really get any boost with ram air setups under 150mph so i'd just set it to 0 for just about any NA car. then the numbers in orange just tell you how much fuel you're using, and how much injector do you need to keep it in the safe (80% duty cycle max) range. very simple, and suprisingly accurate.
By Brett Foote | 2026-06-04 05:00:17
