swapping injectors
Old Jul 4, 2006 | 03:54 PM
1999 SS's Avatar
Default swapping injectors
my dd is a 00 TA with 65k and stock injectors. i have injectors from my 99 SS that have only 15k on them. i know that the 99's are 26lbs and the 00's are 28lbs per hr, would i have any problems swapping them, would i loose any perfromance, would i need to do any tuning to make them work?
Old Jul 5, 2006 | 05:15 PM
Lethal_Ws6's Avatar
i thought 2000's also had 26lb injectors also .. 99-00 ..
Old Jul 6, 2006 | 07:34 AM
slow trap's Avatar
it you put in 28.8 lbers it will probably run rich unless you have it tuned.
Old Jul 6, 2006 | 03:50 PM
slt200mph's Avatar
the 2000 cars had 26's in them
slt200mph's Avatar
the 2000 cars had 26 lb. injectors in them
Old Jul 10, 2006 | 06:45 PM
1999 SS's Avatar
i didnt know that 99 & 00 injectors were the same. so it would be a simple swap no other work needed?
Old Jul 10, 2006 | 07:19 PM
BriancWS6's Avatar
Simply swap them out and then more than likely a re-tune.
