Fuel Pressure Still Dropping...
-8 Feed line to LS1 Speed Rails
60# Motos
Aeromotive FPR 1:1 at rails
50psi idle
~13 vacuum
+12psi
75psi fuel pressure during WOT
pressure raises fine but towards 5k the fuel pressure drops and at redline its back to 60 or so psi..
Any1 else having fuel pressure dropping
I also read on ls1tech that walbros dont like high pressure...and was wondering if I set them straight to 58psi with no vacuum/boost reference..would that let them flow within there rated range?
If you have enough injector, you can set them to 58psi and they will flow better...just remember 58psi minus your boost psi = what the injectors see.
Is this happening with more than a 1/2 tank of fuel in your stock fuel tank? Just a quick sanity check to rule out fuel pump starvation under acceleration.
You're sure both 255 pumps are really working? They do have a weakness at higher fuel preasures but I don't remember the trigger point for problems.
Are you sure the boost reference source line to the FPR isn't leaking or coming loose?
We've been running at 60psi base fuel preasure on the Mototron 60s with the Weldon boost refernced FPR without any issues at 15lbs boost. We even had a cool day last November where we ended up cranking up the base fuel preassure some more to squeeze out a little more fuel during testing. The injectors didn't have any problems getting pushed this hard.
So I'd lean towards one of the pumps not being happy if the boost reference line looks ok to the FPR.
Rick
full tank of gas
vacuum line is good (I always have 13psi of vacuum - if the line were to become disconnected or something...I would have 8psi of vacuum)
using a Autometer Cobalt Fuel Pressure Regulator
pumps probably have less than 500 miles on them
also have the racetronix wire kit for single pump
As stated before.. You sure obth pumps are on? Mine are much louder. Also I did a setup just like yours -8 breaded line all the way to the engine, W/a full return line. Dual Walbro's intank.
He's got a 396 LT1 with 11psi of boost and he's putting down the numbers, + his fuel pumps are quite loud when they prime up..
Maybe 1 pump is not happy, failing.. Maybe your not running both pumps. Like said in the other thread you need to make sure both are on..
Talk to you later.
Clint
Rick
i will re-inspect the pumps to make sure they are BOTH running.
dirty filter on upstream side
damaged/bad regulator
good power and grounds to pumps
good flowing Y block from pumps, no restriction inside the tank.
solid voltage to the pumps
weak pump?
when i was dropping pressure i ran new dedicated grounds to the pumps and re-did he y block and havent had a problem since
995rwhp through a T400 and stock feed line, 43psi base pressure.
My own car which has made 898rwhp, 43psi base pressure.
And on a few customers cars at 70psi base pressure. (pushing 60's)
I would check the things MM has suggested. Also, does pressure bleed down or stay steady after the key is turned off? A pinhole in one of the lines inside the tank could do it as well.
We pm'd each other a few weeks back regarding this issue with stock feed lines...keepin' my fingers crossed!
We usually run 83's on cars with BS3, up to 1000rwhp.
but if i dont turn the ignition off...the pressure starts to slowly drop.
i take it that both instances i just described are normal?
I am pretty sure the fuel pressure is dropping it evident in my dyno runs where my A/F will start to decrease after 5k and no matter how much i open the injectors/PE vs RPM/VE table...the A/F curve doesnt richen up.
