Need some feed back on this product!!!
Old Jul 8, 2006 | 09:34 PM
red fury's Avatar
Default Need some feed back on this product!!!
Say this over on Jeg's webpage for LT1's-LS1's and it runs $82.99
"Casper Electronics VPlus Volt Booster"
Your charging system is designed to maintain normal battery voltage under ''normal'' conditions. However, when you modify your ride with upgraded injectors, fuel pump, and ignition systems, you need more power. The top of the engine RPM scale is where it's needed most.
The VPlus is designed to ''plug-and-play'' into your GM vehicle and provide around 2 extra volts to the electrical system at wide-open-throttle. This gives your engine more power for a hotter, more efficient spark in your ignition system. It also keeps the fuel pump at its peak performance level to maintain proper fuel pressure and volume.
Note: Drive-by-wire applications not available. Can be used in conjunction with the fuel pump wiring upgrade kits..
I like the idea of throwing more juice to the plugs as much as I like giving my Walbro 255lph intank pump a little support since it is on the factory wires.
What do you all think??? And if you are using it please give some info on it!!
Old Jul 8, 2006 | 11:16 PM
kp's Avatar
kp
https://ls1tech.com/forums/forced-induction/536014-casper-electronics-v-plus-volt-booster.html
Old Jul 8, 2006 | 11:31 PM
red fury's Avatar
thanks kp!!
