Putt Putt Mobile...What Gives???
Old Jul 22, 2006 | 12:28 PM
Spoyld029's Avatar
Default Putt Putt Mobile...What Gives???
Alright, I'm praying you guys can help me. I have a 98 Trans Am and recently it has become possessed and occasionally when starting it up, putting it in drive, and coasting out of anywhere, it will start to idle like it wants to stall, if I give it gas it acts like it's getting none, if I let off the gas it will idle really rough and go very slow making a putt putt noise while it does, stinking very strongly of gas. Originally it was throwing codes indicating the O2 sensors were bad. So, I replaced them. Then it began throwing "multiple cylinder misfire" codes....So, I had new plugs and wires installed. Then no codes were thrown, but the car would occasionally do this same stalling thing. I then went on to replace the MAF, the PCV valve, and the fuel filter and STILL....the same thing I had the fuel pressure checked and it was around 50. It will do this for a little while and then you can hear the car "right" itself and then it runs fine. Right now there is no SES light on but still it's a gamble from start to start whether or not the car will do this. Does anyone have any ideas what could be causing this or where I might look next?
Old Jul 27, 2006 | 11:39 PM
sping012's Avatar
hmm i had the EXACT same problem when my O2's where dead, did you make sure to change both sets of O2's the front ones are the ones you really want to check.
Old Jul 28, 2006 | 05:14 AM
Spoyld029's Avatar
Yes, we changed all of them...We have also checked for vacuum leaks, bare wires, checked ground wires and still....NOTHING... Some are saying it could be the fuel regulator or a fuel relay....does anyone know how to test those?
