max power on single in tank f/i ?
i know this has been beat to death but my searching skills aparently aren't that great.i have been thinking of going with a procharger setup and would like to be in the 550 + range.i have the racetronix p-n-p single and that is it.is that much atainable somehow with a single,maybe add a boost a pump ?
thanks,mark
thanks,mark
mine was giving up around 514/570, afr was leaning out quickly in the end.... racetronix intank with harness, nothing else, and 83lb injectors. went to the A1000 and sumped the tank.. now fuel is good.. gotta get her back on the rollers and crank it up now!
Chris
Chris
I made 549/612 with a single Ractronix. Tho I also have the ATI in-line + an Aero 1000 regulator. But I hold 60 psi at 6500rpm+ runniing PIG rich. The only issue is the bucket in the tank seems to run dry if I have less than 1/2 tank (fuel pressure drops like a rock).
