external fuel pump for daily driving?
Old Jul 25, 2006 | 11:33 AM
KHShapiro's Avatar
Default external fuel pump for daily driving?
who is using an external pump for daily driving?
What kind of issues?
How many hours of use before turning off the car?
How many hours of use before the pump starts to fail?
How quite?
How much hp are you supporting?
i am looking for an external pump to handle 90+ lbs injectors , FI , on a daily driver.
what i am not looking for is a twin in tank or aeromotive a1000 or anything aeromotive.......... unless its some new aeromotive product that is super secret and really works.
i did see this thread https://ls1tech.com/forums/fueling-injection/458260-external-fuel-pump-please-vote.html
does anyone else have any other ideas?
Old Jul 25, 2006 | 01:58 PM
Nasty N8's Avatar
How's it going have not heard from you in a while. The MagnaFuel is a great street pump very quiet and does not create heat soak even without a voltage controler (not rec.).
who is using an external pump for daily driving? Most people I sell pumps to
What kind of issues? None yet
How many hours of use before the pump starts to fail?several we drove one to a track 3.5 hours a way and hot lapped it and drove it home
How quite? Extremely I was suprised it is the quietest external pump I have used
How much hp are you supporting? They have one that is upwards of 2000hp
Nate
Old Jul 25, 2006 | 02:45 PM
KHShapiro's Avatar
Mr. Nasty Nate, as i am sure you are well aware,these build ups cost a ton!
i changed cars completely no longer doing a 4th gen.
now after a few years of this project i am headed into the final few challenges of the build.
What information can you send me about the Magnafuel pumps including pricing.
now this is for an FI if that changes anything.
Anyone care to sound off about using the MAgnafuel pump?
Old Jul 26, 2006 | 01:40 PM
KHShapiro's Avatar
up up up
Old Jul 26, 2006 | 01:59 PM
V6 Bird's Avatar
Nate
Ive never had an issue with an A1000. That is of course when they are setup right...If you mount it with MSD viabration dampners its pretty freaking quiet. Ive seen some nightmare installs on them. Ive seem people mount them in the location where the stock fuel filters are and not be able to drive less then 45 minutes without the car dying. The voltage controllers for street duty in my opinion are a joke.
I ran my power supply right off the alternator and never once had an issue with heatsoad, vaporizing etc...Like ive said before, if its setup right, you shouldnt have any issues.
My setup consisted of a sumped 98 tank...filter...A1000...y at the back of the rails...each line into a side of an aeromotive boost referenced regulator...return out the bottom to the top/front of the tank. I used 4 gauge wire to supply power and ground with a nice bosch relay. It turned on with the key on. I drove it all over the streets, in traffic, sitting idling, not a sign of an issue.
Old Jul 26, 2006 | 03:18 PM
KHShapiro's Avatar
Are you using the car on a regular basis? how many hours and or miles at a time?
Thanks
Old Jul 26, 2006 | 04:19 PM
Nasty N8's Avatar
ProTuner Series
Engine Hp: up to 2,000+ NA
Once-piece design is more compact and light weight.
* Ideal for street muscle cars
* Quiet operation
* Self priming
* Continious duty
* No pump shaft seals, no leaks
* Pump body CNC machined aircraft aluminum
* High-torque custom motor with very low current draw. Never requires stepdown
* More efficient than other motors
* Double support bearings
* Rebuildable to as-new condition
* Compact design fits in smaller spaces
* Smaller than competive pumps, lower current draw, more powerful
* Hard anodized, long lasting finish
* Mounting bracket included
* Vertical or horizontal mount
* Polymer wear plates for smooth, quier operatio
MP-4303 2,000+NA HP 20–120psi 14A@45psi #8AN in and out 7"L x 3"Dia 4.5 lbs.
MP-4301 1,500+NA HP 20–120psi 12A@45psi #8AN in and out 7"L x 3"Dia 4.5 lbs.
MP-4302 1,000+NA HP 20–120psi 10A@45psi #8AN in and out 7"L x 3"Dia 4.5 lbs.
MagnaFuel inline compact, light weight and super quiet street fuel pumps MP-4301, MP-4302, MP-4303 up to 2000HP capability Retail $539.99 Call for pricing
They tell me the 4301 should do just over 1000rwhp on a turbo car and the 4303 is good for over 1500rwhp I have yet to have someone max them out.
Nate
Old Jul 27, 2006 | 07:24 AM
V6 Bird's Avatar
Thanks
It was my daily driver for 2 years...
Went to Oklahoma, Louisiana...I was never afraid to fill up the tank and just drive for hours on end to go party, gamble and hang out with out of state friends with it. Get there, hit the street scene, win some money and come back.
Old Jul 27, 2006 | 09:59 AM
Boostaholic's Avatar
I have twin A1000 pumps in my DD, seems fine so far except they are a little loud but that doesn't bother me.
Old Jul 28, 2006 | 11:55 AM
V6 Bird's Avatar
Mount them on the MSD vibration dampners you get in the ignition box kits...youd be surprised how much quieter they really are.
