FAST Fuel Rail install?
Old Jul 29, 2006 | 03:33 PM
davered00ss's Avatar
Moderator
Default FAST Fuel Rail install?
Anyone have a link to a HOW TO on this.
Old Jul 29, 2006 | 03:34 PM
Moderator
I bought the rails, but have not yet got the fittings and fuel line. thinking of getting the kit from Nasty, but may just get them from the local speed shop.
Old Jul 30, 2006 | 12:42 AM
erikthegoalie's Avatar
im doing it right now....i can help..PM me and ill walk you through what you see in the pic....
erik
Old Jul 30, 2006 | 06:54 AM
Moderator
Thanks, I probably will PM you when I start the install. I have not gotten the rails in yet. Just ordered them Saturday. Not sure if I want to order the kit, or just buy the fittings locally.
Old Jul 30, 2006 | 08:55 AM
well, i bought the install kit from speed inc....
the set backs i will have is that there are no instructions...so, I will wing it, but as far as the fittings they are all included....you just haveto know what goes where which is easy!
erik
Old Jul 30, 2006 | 11:25 AM
Moderator
My issues will be how to hook it up to the factory line & what to do with the vaccume line in the front of the intake.
Old Jul 30, 2006 | 03:57 PM
true.....i am there right now...
I will keep ya posted
Old Jul 30, 2006 | 05:54 PM
Moderator
Get some pic's.
Old Jul 30, 2006 | 07:39 PM
i havent started yet, i was saying i am in the same boat as you...when you buy the speed inc set up, it will comes with two special fittings specially made to connect directly to the stock fuel line...
you get a fuel line disconnect tool...diconnect the line...and attatch it to the new braided line with the fitting...
now as far as the vacuum goes, im not sure myself yet...
Erik
Old Jul 30, 2006 | 08:16 PM
1 last 1's Avatar
subscribing...
Old Jul 30, 2006 | 09:23 PM
welcome
Old Jul 31, 2006 | 11:35 AM
Nasty N8's Avatar
The "vacuum line" (tank vent) is a completely separate line no need to do anything with it leave it as it is. The heat wrap just holds the 2 together.
Nate
Old Jul 31, 2006 | 12:48 PM
Phoenix 5.7's Avatar
good luck. im hopin to pick up a set of Nasty's rails when i get soem money. Im just guessin, but im guessin they want to do something to move or modify the EVAP line. i have a writeup when i relocated mine here:
http://www.clubhioctane.com/communit...read.php?t=713
Nate might have a suggestion on what braided line to use instead of regular rubber fuel line.
Old Jul 31, 2006 | 03:58 PM
Nasty N8's Avatar
You could use braided line for looks but that fuel line would be just fine.
nate
Old Aug 1, 2006 | 03:13 PM
Moderator
Ano one have a pic of how the kit's come? Before install.
Old Aug 1, 2006 | 03:37 PM
RW99's Avatar
Maybe a little off-topic, but just be aware that the FAST rails interfere with alternator relocation setups on that passenger side. ARRRGGGHHHH!
Old Aug 1, 2006 | 05:18 PM
Nasty N8's Avatar
Here is our install kit.
Old Aug 1, 2006 | 06:28 PM
Moderator
So you have to cut that fuel line yourself.
Alternator relocation? For a FI application?
Old Aug 1, 2006 | 07:49 PM
SIC LSX's Avatar
how much is that kit?
Old Aug 2, 2006 | 11:54 AM
Nasty N8's Avatar
Yes you have to cut the fuel line yourself to get exact lengths.
The FAST install kit is $125
Nasty rail install kit is $100
Nasty Rails are $179.99
All are in stock
Nate
