recomend an injector size please
5.3L Turbo with the 42# injectors on 15psi i had the injectors at 160% and the car didnt pull much.
So i switched it to 5psi and the injectors ran at around 80%. Ran good.
this was on a stock cam.
Im now putting in a 224/224 .581/.581 112 cam and want to run 15psi
what size should I buy? what kind are better?
And does the factory PCM run on high or low impedence? Im running the factory PCM w/ 2 bar HP tuner SD.
Thanks.
