TB cleaning solution...
Old Aug 1, 2006 | 04:40 PM
Superado's Avatar
11 Second Truck Club
Default TB cleaning solution...
Have read carb cleaner is too harsh...have also heard bs called on that...
have read to mix fuel inj cleaner w/ gas and use...
have heard...I just threw it in the parts cleaner and in the morning it was clean...
what experiences have you guys encountered...going to have the TB off to retap a hole for a jet and thought I'd clean it while I had it off and finally do the coolant by-pass as well...
Old Aug 1, 2006 | 04:42 PM
Superado's Avatar
well, I had a thought about how seafoam is petroleum based, so I called them...
supposedly, it works great as a TB cleaner and will not harm any of the finishes on the TB components nor harm any seals or o-rings either...
on another seafoam note...I told the guy that I was planning on doing the top-end clean so I would already have some seafoam that I could use on the TB...he asked what vacuum source I planned on using and I told him the brake booster line...he said that it would not evenly distribute the product in the intake to all runners...he said that the best source was whatever vacuum source is closest to the TB, engine side of the TB of course...he suggested getting the Deep Creep product instead of the liquid and use the provided tube to spray into the vacuum line w/o actually inserting the tube into the vacuum line because it needed air and product...he said to do this with the engine running, using a half a can or so...shut off engine...let sit for 5 minutes and then go driving...this contradicts everything I have ever read here or on any other forum for that matter...hell...it even contradicts their own directions on the can...
Old Aug 1, 2006 | 05:16 PM
Nasty N8's Avatar
I use 3M TB cleaner works great.
Nate
Old Aug 3, 2006 | 09:59 AM
Superado's Avatar
Nate
I saw that at O'Reilly last night...
I think that I am going to go with the Sea Foam "Deep Creep"
Old Aug 4, 2006 | 04:57 AM
Silverback's Avatar
Seafoam is acetone based… it will melt some plastics and cause rubber to swell. O-rings will become too large to fit in their seats but usually the will shrink down some again if you let them air dry for a while, but it is not good for them (makes them brittle)
Old Aug 4, 2006 | 08:26 AM
Superado's Avatar
Not sure where you got your info about SeaFoam...
SEA FOAM MOTOR TREATMENT for Gas Engine Applications
100% Pure Petroleum
Use in All Engines in All Seasons
2 Cycle, 4 Cycle, and Diesels
Treats 3 Critical Areas: Gas Tank, Fuel Systems, and Crankcase
and then there is also DeepCreep:
Cleans, penetrates, lubricates and dries, all from a 100% pure petroleum product. For use in all 2 and 4 cycle gas and diesel engines. Spray into carburetor to start engines. Use to clean and lubricate air tools, door locks, and guns. Hundreds of household and shop uses. DEEP CREEP works with instant action and is oxygen sensor safe. DEEP CREEP is SEA FOAM in an aerosol can.
Old Aug 4, 2006 | 08:30 AM
Superado's Avatar
DeepCreep as a TB cleaner:
Run engine to normal operating temperature.
Shut engine off and disconnect air intake boot.
Spray DEEP CREEP into throat with throttle plate open. Saturate and soak. Clean with a soft toothbrush or cloth if necessary.
Spray into throat with straw attached to finalize cleaning.
Reconnect air intake boot and drive.
Make sure exhaust is well ventilated as fumes may be extreme for a short time.
Safe for teflon coatings, lubricates bushings.
Old Aug 4, 2006 | 01:54 PM
Silverback's Avatar
Well, acetone is a pure petrolium product...
By Brett Foote | 2026-06-04 05:00:17
