which LocTite should be used...?
Old Aug 1, 2006 | 04:55 PM
Superado's Avatar
11 Second Truck Club
Default which LocTite should be used...?
on a stainless steel threaded insert tapped into an aluminum TB...
Old Aug 3, 2006 | 09:59 AM
Superado's Avatar
no one?
Old Aug 3, 2006 | 10:09 AM
EDS01SS's Avatar
dont use any loctite.use anti-sieze
Old Aug 3, 2006 | 10:27 AM
Superado's Avatar
have used it before on different applications...unless there are different types of anti-seize...it's messy and could possibly end-up in my intake I would think... and has no holding strength to prevent backing out of the insert either...
Old Aug 3, 2006 | 04:27 PM
EDS01SS's Avatar
no there is only one type of anti-sieze.The likelyness of the steel bolt backing out of aluminum is slim to none.without anti-sieze the threads will get screwed up on the aluminum when the aluminum gets hot. Unlees your gobbing the anti-sieze onto the threads i wouldnt be concerned with it getting into the intake.
Old Aug 3, 2006 | 05:30 PM
Country Boy's Avatar
Senior Member
ummm.. hes not talking about a bolt. Hes talking about a threaded insert, like a rethread. Id use red.
Old Aug 3, 2006 | 08:58 PM
Superado's Avatar
I contacted Loctite tech and was told to use #271 w/ #7496 Primer.
Picked it up at McMaster-Carr this afternoon.
Thanks guys...
Old Aug 4, 2006 | 04:48 AM
Silverback's Avatar
There’s TONS of different types of anti-sieze. Most common ones are the aluminum, copper and ceramic based…
If you’re trying to make a threaded insert pretty much permanent in an aluminum casting I usually use a little JB weld on the threads.
