Nasty tank and Magnafuel 4303 install pics
Originally Posted by SVC707
i did not know where to put mine. its bolted to the trunk right now so i could get the car to a shop. but im having a true dual setup fabbed and will either steal your location on the upper bar or mount where the ehaust hanger used to be
I looked at that spot, but Im lowered and Im a true street car (18s, neons, BIG stereo, DD, etc...) I was afraid of a big dip taking the pump any everything off.. Ill snap some pic of my setup this weekend. Itll be pretty trick!
Edited because beer > me...
my car is actually a street car also. but the pump assy hides behind the rear bumper. i dont think it can hide like that on yours. i am also running two jl amps and 2- 12's. 18' simmons, but i have GC coilovers. i have a plate inside the trunk to make it stronger. oh but you have your speakers in the trunk huh?
i made this last year:
so i have total trunk space available. i was almost tempted to mount the whole pump assy in the trunk.
you cant see the pump assy:
I have a little bit in the trunk https://ls1tech.com/forums/wiring-stereo-electronics/452304-pics-my-new-setup.html
Originally Posted by frcefed98
Looking good Kev one day i'll step up to the big pump and shiny aluminum tank but i'll have to wait till I get a 12 bolt before doing that.
J
J
FWIW the 'heavy' 98 tank only weighed 3lbs more (without the sender/pumps) then the aluminum tank. Poeple claim the 98 steel tank is 20lbs heavier then the 99+ plastic tank but that cant be true at all..
Originally Posted by andyws6
kp,
How did you do the trap door thing in the hatch area and the vent on top? Was it difficult? I think I am going to do that also.
Originally Posted by kp
You dont need to have much of a hole just to do the vent. On the newer nasty tanks I dont know if you can get your hand in the sender hole to put the rollover valve in the tank. My tank is an older one with the big hole for the stock 99+ sender.
#32
I was thinking about that, but I almost have to try. I can't stand the current situation of the vent on this tank.
#33
i got my car running last night and mounted the pump on the panhard bar with out seeing your pics.... kinda funny...
but i am kinda unhappy about the whole vent thing.... it takes forever for it to get gas and it has no baffles and when i hooked up the stock replacement fuel sender it didnt read any fuel with 5 gallons in it....
but i was just really glad to hear it idle... sounds mean as ****!
#34
Kind of a logical place to put the pump, if you still have the upper panhard on anyway
Vent on mine works fine, I can go to a gas station and fill it up like a normal car. Cant really see why the vent on the side would be any different unless its just too small.
I made my own 0-90 ohm sender setup and reprogrammed the PCM to work with it, 2 gallons is on E and full is like 3/4 so its usable. Glad to hear its running, mine is in 1000 pieces again..
#35
#37
As far as the sending unit goes, unless you replace it with a different kind which I wouldn't even know where to start) you are just going to have to live with it. All of us have the 5 gallon fill up problem. As far as the vent thing goes there are a couple of things you can do. There is one guy on here that uses a catch can. But if you are like me, that won't be good enough. I will probably drop my tank and put a vent valve on top like kp did. It's a lot more work but it is the best fix I can think of. Good luck on whatever you choose
#38
The reason the side one is a pain is that it is lower than the fill neck. So if you fill up, gas starts leaking out the vent and you car looks like it's taking a **** all over the concrete. Not to mention that it no longer functions as a vent at this point. That's the problem
#40
My vent is lower then the highest point, it has never spit any fuel even with a 1.29x 60 foots nearly full.
