Injector help quick
Old Aug 5, 2006 | 09:07 AM
Ta9864dodge's Avatar
Default Injector help quick
I am running a 98 trans am with ls6 heads, hot cam and intake, nothing extreme. I had my car programmed using the 28.8 injectors but at the last minute they died so I threw some of those ford svo 30's in there, but used the same program. Could this be causing me slow throttle response issues, bogging? and could I get away with going back to the stock 28.8 injectors?
I need to know quickly cause there are some on here for sale, Thanks.
Old Aug 5, 2006 | 11:36 AM
slow trap's Avatar
your car is running very rich. i think the svo injectors are actually either 35-37 lbers at our fuel pressure.i would get some more 28.8 lbers .
Old Aug 5, 2006 | 04:36 PM
ZL1Killa's Avatar
when you change injectors you MUST change the tune in the car.... otherwise it will run crappy
Old Aug 5, 2006 | 05:12 PM
I was pretty sure that was the problem, I was just in a jam cause the stock ones wouldn't clean up and I had the Ford ones new lying around. I will try and find some factory ones to solve my problem, Thanks for the help.
By Brett Foote | 2026-06-04 05:00:17
