Fuel rail question...
i have a set of aftermarket rails that are for an aftermarket intake, and all the fittings i have are -8 stuff. just don't want to spend all that dough again on the fittings/hose/etc...
otherwise i have to figure out a way to mate up these rails to work on a stock intake and I don't trust stuff like that.
Chris
Just my thoughts...
-Jamin
each part of the rail fits an -8 to -8 male, then the hose has it's fitting that is a -8 that gets screwed on the male end that is in the fuel rail
but yes, if you go through summit, it lists out the -8 size fitting that would get screwed into the rail. it's not the 3/8 npt size that speed inc normally carries
http://store.summitracing.com/partde...5&autoview=sku
like that, but with the ability to have that same Speed Inc. style hold down.
my current rails, the fittings that go into them are -8 o-ring to -8
since i need rails either way, i don't feel like buying rails that are the 3/8npt and having to get a 3/8npt to -8 female connector
i like things uniform and getting the correct parts. not buying different adaptors just to make something work. i wouldn't have to by JUST ONE adaptor.
I'd need a 3/8npt plug for the passenger side front of the rail (i'd have the -8 laying around then)
then i'd need (3) 3/8" npt to -8 female connectors so that I could adapt my current AN fittings to the smaller rails
i'm just trying to use what i have available without having to discard of the other AN fittings I just got. So those are 3/8npt to -8 fittings in those rails, correct? looks like no response from nasty, and i know speed inc. doesn't, so looks like this is my only answer
