Is this bad for the Walbro?
Old Aug 18, 2006 | 08:45 AM
ArcticZ28's Avatar
Default Is this bad for the Walbro?
I was just reading about how some people have the Walbro installed with the bottom of the bucket cut out and the filter sock hanging out of it. However, mine was installed without cutting the bottom of the bucket and the filter sock just kinda sits at the bottom of the bucket and tucks up around the pump. Could this cause problems?
Old Aug 18, 2006 | 04:05 PM
Sixspeed042's Avatar
possibly. wouldn't worry about it though. if you mess up, collect your loss and spend another 100 for a new one.
Old Aug 18, 2006 | 08:43 PM
ArcticZ28's Avatar
Well, like many others mine took a crap after 1500 miles and I never let the tank get empty. So, I was wondering if anything done installing it this way would have such an effect. In no way will I buy another Walbro if this one fails. I'll spend $500 on a pump that'll work.
Old Aug 18, 2006 | 11:19 PM
onfire's Avatar
Coal Mining Director
Did you get the Racetronix kit with the siphon? If not, how did the bucket fill with gas? That may be why it failed.
Old Aug 18, 2006 | 11:21 PM
ArcticZ28's Avatar
Huh? The walbro pump just fits down into the stock bucket which is then submerged in the tank. What siphon are you referring to?
Old Aug 19, 2006 | 06:27 PM
onfire's Avatar
Stock pu,p on 99+ cars has a siphon hose that attaches to the pump to refill the bucket.....unless you intalled a Racetronix pump that includes the siphon hose, you need to cut holes in the bucket to let the gas into the bucket. If not the bucket will empty and burn up the pump.
Old Aug 20, 2006 | 02:34 PM
ArcticZ28's Avatar
Hmmm, yea I don't have a siphon on this bad boy. Where is the siphon located/attached? All I have are the two hoses on top attached to the pump. Nothing goes down into the tank on the bottom. Just a fuel sock there.
Old Aug 20, 2006 | 07:36 PM
cablebandit's Avatar
mine is hacked up at the bottom....works fine and i run mine until the "check gauges" light comes on. I got both of mine right at the bottom of the tank.....
Old Aug 20, 2006 | 07:52 PM
ArcticZ28's Avatar
Wait, is this siphon hose a reddish color? B/c there are two tubes in the top of my pump, is one of them the refill tube?
Old Aug 21, 2006 | 01:30 AM
navymitch12's Avatar
when i installed mine i just cut a large "window" in the side of the bucket so it gets fuel, and than cut a hole in the bottom and stuck the pump out of there and than attached the sock to it. you can see the sock in this pic.
Old Aug 21, 2006 | 05:06 AM
ArcticZ28's Avatar
Gotcha. And where is the siphon I keep hearing about?
Old Aug 21, 2006 | 08:08 AM
dont need it if you cut the bucket up
Old Aug 21, 2006 | 09:32 AM
KAOS's Avatar
i have a 98 and i bought the plug and play setup from racetronix, so anything special i would have to do?
Old Aug 21, 2006 | 03:37 PM
ArcticZ28's Avatar
I still don't know where to cut the bucket. Anywhere around the side will do?
Old Aug 21, 2006 | 04:01 PM
98_Formula's Avatar
same here, i just got done installing the racetronix "plug and play" setup... which it was far from... you don't have a bucket, but when it came to wiring, the unit i got from racetronix was missing two wires which i had to pull out of the old unit on the car and put on there unit... but no bucket here though so i think ur safe in that category
