How to install injectors
Old Sep 3, 2006 | 03:53 PM
Ricky_GD's Avatar
Default How to install injectors
hi as some of you know i have a leaking fuel injector, i have taken apart check and installed again but no luck, it leaks from where the injectors sits in the rail, anyideas? rubber o ring seems fine. am i doing somthing wrong when installing??/
regards
Old Sep 3, 2006 | 04:29 PM
oange ss's Avatar
leaks when you trun the key to on, or while the engine is runnin ?...be sure to use oil or Vaseline on the o-rings before installation
Old Sep 3, 2006 | 04:33 PM
Ricky_GD's Avatar
both. will try that thanks
Old Sep 3, 2006 | 04:37 PM
oange ss's Avatar
sounds like the injector is stuck open, shouldnt be any gas runnin thru it with just the key on.......
Old Sep 3, 2006 | 04:43 PM
Ricky_GD's Avatar
ok, turn the key on and the fuel pump pressurises the system, injector starts to leak. start engine and still leaks. i have swapped injectors over and still leaks.
cheeers
Old Sep 3, 2006 | 04:49 PM
oange ss's Avatar
injectors shouldnt cycle till the PCM gets an RPM signal....leakin with the key on means the injector is stuck open....if you swapped the affected injector with the same results then you have more the one leaking injector...there's no other explanation for it
Old Sep 3, 2006 | 04:55 PM
Ricky_GD's Avatar
but its not leaking frlom the bottom of the injector! its where the injector clips into the rail.
Old Sep 3, 2006 | 04:58 PM
Ricky_GD's Avatar
are the orings just standard o rings? or are they special and have to get from GM? also where can i get the clips from?
regards
Old Sep 3, 2006 | 05:01 PM
oange ss's Avatar
then it sounds like a sealin problem...you can usually get o-ring kits from parts stores....clips i think only from dealer and you have to buy the manifold/rail assy....be sure to use plenty of lube on the new o-rings...good luck
Old Sep 3, 2006 | 05:09 PM
Ricky_GD's Avatar
your joking? i cant just buy the clips? bugger i broke one yesterday.....
Old Sep 3, 2006 | 05:12 PM
oange ss's Avatar
the clip thing was brought up before and i'm pretty sure that's what the outcome was IIRC...you can check for yourself
Old Sep 3, 2006 | 05:24 PM
Ricky_GD's Avatar
cheers are the ls2 clips the same? just looked on gm part numbers and you can buy them seperatly as they have a part number.
Old Sep 3, 2006 | 06:04 PM
oange ss's Avatar
not sure, i think the injectors are taller but dont see why that would have an affect on the clips
Old Sep 3, 2006 | 06:07 PM
Ricky_GD's Avatar
http://cgi.ebay.com/ebaymotors/GM-Fu...QQcmdZViewItem
shame its in the states. wounder if the bloke will ship to me.
Old Sep 3, 2006 | 06:08 PM
oange ss's Avatar
dont see why not, it wouldnt be a big package
Old Sep 3, 2006 | 06:11 PM
Ricky_GD's Avatar
we will see. going to hunt around some places in the uk tommorow (12am here in the UK) then will use him as a last resort.hopfully it wont take that long for them to arrive.
thanks for your help. just need to sort this leak now!!
regards
Old Sep 3, 2006 | 06:13 PM
oange ss's Avatar
np..good luck
Old Sep 6, 2006 | 05:08 AM
RedWS6 00's Avatar
regards
I got a spare set of stock injectors, but they may have a few miles on them. Changed them at 114,000miles, dont know if they have been in the car from new, but worked fine before I removed them, just wanted to go large.
By Brett Foote | 2026-06-04 05:00:17
