meth kit and fuel system?
Old Sep 15, 2006 | 02:41 PM
trouse40's Avatar
Default meth kit and fuel system?
ill be running at about 6-10 psi and makin around 600-650 at the wheels i have a 255 walbro now and some say it them anywhere from 500-600rwhp, will adding a meth kit help my weak fuel system?
Old Sep 15, 2006 | 03:30 PM
MIGHTYMOUSE's Avatar
yes, it will be a stretch to cover the volume you won't have, but it could.
Old Sep 15, 2006 | 03:40 PM
C.W.A's Avatar
I made 600rwhp with a 255pump,60pound inj,and a KB boosta pump!
try the boosta pump it will help!
Old Sep 15, 2006 | 05:18 PM
trouse40's Avatar
where can i get the bap? how much?
Old Sep 17, 2006 | 04:02 PM
WAHUSKER's Avatar
I just added an Alky Control meth kit & KB BAP & picked up 40hp & 50lbs of tq (618, 760). And my fuel pressure holds steady at 60 psi now, where it used to drop to 45-ish. But this is the upper limit of the lines & fuel rails. So if you hit your mark, your at the end....but yes both of these mods can help you.
But the bad news is, my car now SHREDS my Hoosier DRs from a 30mph roll in 2nd gear. I used to stick pretty good. As soon as the blower hits 4lbs & the meth pump turns on, I get this horrible shuddering & shreaking from my tires.
Old Sep 17, 2006 | 09:41 PM
Slowhawk's Avatar
LS1Tech Sponsor
Meth works if you need it.Your power level with a good intercooler shouldn't need Meth at all unless the fuel system is bad like you say.
I just used an Alky control on a car to make a track deadline.It really helped on the top end were the fuel just died.It made up 200hp for me but it was a dual nozzle at full tilt.
Old Sep 17, 2006 | 11:29 PM
Julio's Avatar
Well what did it run.. didnt hear my phone go off saturday so i'm guessing ok
Old Sep 18, 2006 | 06:00 AM
Slowhawk's Avatar
LS1Tech Sponsor
Good,I'll pm ya
