Need fuel pressure regulator or boost a pump?
Old Sep 15, 2006 | 08:41 PM
bowtieman81's Avatar
Default Need fuel pressure regulator or boost a pump?
I have about a 5-8 psi fuel pressure drop at WOT under boost. I don't like that, so I want a little advice on how to fix it. Current fuel system is racetronix pump/harness, 42 lb green tops, everything else stock.
I also have an asp underdrive pulley.
I am wondering if a boost a pump would help, or if I truely need a boost referenced FPR?
Forgive the post, I am sure it has been answered but I get a white screen when trying to search.
Old Sep 15, 2006 | 09:58 PM
NOSjohn's Avatar
Restricted User
Try a Racetronix wiring harness first, it will give more voltage to the pump...or "hot wire" it yourself. Yes, you can also use a boost-a-pump.
Old Sep 16, 2006 | 12:28 AM
ls1king000's Avatar
Is there a hot wire write-up somewhere?
Old Sep 16, 2006 | 01:18 AM
JAvenger007's Avatar
i think hes already got the harness.
Old Sep 16, 2006 | 01:20 AM
Got Me SOM's Avatar
more than likely he has the plug in harness
some fuel press drop is normal but you could add a bap to be safe. I know my car drops some under w.o.t.
i will be adding a bap to help this cause i plan on making more power down the road.
Old Sep 16, 2006 | 09:38 AM
Ya, I have the racetronix harness already. The car is not running lean, still have a WOT a/f of about 11:1, but I hate having a fuel pressure drop because it is hard to monitor.
The only thing I wonder is if my underdrive pulley is hurting the voltage produced by the alternator. Wish I could measure output voltage at WOT.
Any recommendations on a BAP?
Old Sep 16, 2006 | 09:44 AM
Got Me SOM's Avatar
I think you are answering your own question since the accessories are spinning slower.
Old Sep 16, 2006 | 09:47 AM
NOSjohn's Avatar
Restricted User
Exactly, I think I mentioned before to get rid of the UD pulley...both on here and on da' phone.
Old Sep 16, 2006 | 10:14 AM
Hell, John now I remember you did say that
Well, sometimes you have to learn the hard way right?
I think before going to a BAP I will throw the stock pulley back on and see what happens.
Old Sep 16, 2006 | 10:47 AM
Smearin's Avatar
Well if your Fp is at 62psi and drops to 60 or 59... do you really think its nessacery to add a bap... seeing that you still have the fp?
Old Sep 16, 2006 | 12:02 PM
Well, my FP runs right at 60 psi during normal driving. At WOT so far I have seen it drop to 54 psi, but it may drop even more. It is darn tough to watch the gauge real close and drive the thing when the gas pedal is on the floor.
I just was hoping/expecting to not have any fuel pressure issues with my power level.
I will try the stock pulley first and see what that does, if that gets me so that I only have a 1-2 psi drop then that is fine.
Old Sep 17, 2006 | 09:30 AM
Tirefire's Avatar
I have the same problem the only thing I can tell you is to buy a wide band o-2 sensor to monitor your afr.. I bought an lc1, but I think the calibration is off... My normal psi at idle is 58-60 and then drops to about 50 psi at 8 lbs. of boost.
Old Sep 18, 2006 | 07:37 AM
NeverT00fast's Avatar
Do you have a late 03 Z with the C6 fuel system or the older fuel system? I'm having the same fuel pressure drop issue at 6000rpm at WOT also, but I'm only putting out 460rwhp. And I already have a BAP.
Old Sep 18, 2006 | 09:06 AM
Not sure what you are asking. I have the stock 00 f-body fuel system, except for the pump and injectors.
Old Sep 18, 2006 | 09:19 AM
Oops, I read your sig wrong. I thought you have a 03 Z06.
Old Sep 18, 2006 | 06:44 PM
I wish I did!
Old Sep 18, 2006 | 08:38 PM
I wish I did!
It's all good, your ride is alot quicker.
Old Sep 18, 2006 | 10:56 PM
bowtie did that stock pully work out for you?
Old Sep 19, 2006 | 07:26 AM
Don't know yet, I shredded my serpentine belt and don't have the new one yet. Should get it fixed today or tomorrow.
Old Sep 19, 2006 | 07:41 AM
Billiumss's Avatar
I think your wasting your time swapping pulleys.
Your alt has a regulator built in. At idle you should be around 13.5 volts or more. When you got WOT your alt is making more power. Slowing down the alt with a UD pulley reduces the current output, at WOT thats not an issue unless you have a 1,000+ watt stereo going full blast at WOT.
Get a good DMM (Digital Multi Meter), run some wire from the battery to inside the car, connect the DMM to the wires and see what it is at idle. Go drive around and have a buddy read the meter and see what the voltage is at WOT, I'm going to bet the voltage will be the same at idle or higher.
When you moved the alt, did you upgrade the wiring, go bigger?
