fuel line size: turbo, 60lbers
Old Sep 19, 2006 | 07:06 PM
ninetres's Avatar
Default fuel line size: turbo, 60lbers
I decided I am going to install a new fuel line for my car:
LS1, T76gts, 8 psi boost, 60 lb injectors, racetronics pump/hotwire, Fuel lab boost referenced FPR, fuel rails, patriot stg 3 heads, cam.......
What size feed line (single) should I run? I am going to use the stock line as a return. THANKS!
Old Sep 20, 2006 | 02:16 AM
ninetres's Avatar
Wow this forum is dead. *chirp-chirp*
Old Sep 20, 2006 | 11:46 AM
Josh@KY-Turbo's Avatar
I would go with a -8 feed line and -6 or stock line for the return.
Old Sep 20, 2006 | 12:49 PM
Country Boy's Avatar
Senior Member
Thats what I have.
Bulkhead in stock tank
#8 feed
#6 to stock feed as return
Old Sep 21, 2006 | 12:18 AM
ninetres's Avatar
Texum speed sad to stick with the stock lines. He said they have made 700-800whp with one pump using the stock lines and rails.
Old Sep 21, 2006 | 06:09 AM
Senior Member
IMHO, I wouldnt chance it..
Old Sep 21, 2006 | 07:10 AM
Blown SS's Avatar
I don't see how they could say this is possible on a f/i car. I could possibly see it on a n2o car, but I don't see 1 pump and stock lines supporting those kind of #'s.
Right now I'm using meth to band-aid my weak fuel system.
Old Sep 21, 2006 | 11:54 AM
Nasty N8's Avatar
Wow I have never seen 700-800 on one intank pump. Most are lucky to hit 550rwhp on a boost car. Give me a call I can set you up with a complete kit to run your new lines and regulator.
Nate
