My sheetmetal gas tank fills like it has vapor lock
did'nt think I could fill her all the way initially..... only abouit 3/4 or half..... then I started filling real slow and she would fill all the way. I need the roll-over check so she dosen't spew when I turn, but the filling aspect is still an issue. I have 3/8 hose wrapped around the filler neck routed to the top of the fuel fill port for my vent, but it dosent seem to work... any help appreciated.
LS1Tech Co-Founder
I have to slow fill my tank, or it backs up. Any pics would be great. Or you can email to me at john@ls1tech.com and I will host them.
this is what i did but it seems as though its not good enough for some, but the way i see it: does not leak when turning tight right turns or up hill. i can fill it full blast at the pump and no spill either
https://ls1tech.com/forums/fueling-injection/568066-nastyperformance-fuel-tank-vapor-hose-leak-fixed.html
https://ls1tech.com/forums/showthread.php?t=568066
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Mine is nothing special. I can tell you right now it has a K&N filter at the top extactly like the one for you air system whit a aftermarket lid. Then I just ran the hose in a loop like slowhawk told me he did on evils car. The filter is tucked in the inner fender right above the filler neck. And I drilled holes in the inner fender plastic so air could get in there
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by kp
Something has to be wrong if gas makes it that far up the vent, I would probably try not to squeeze so much fuel in. If the vent hose is filling with fuel its not a very good vent ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![](http://img.photobucket.com/albums/v482/svc707/IMG_0340-1.jpg)
btw in the other thread it says that ive tried looping the hose and that didnt work after a few right hand turns itll still come, but i didnt run the hose that high
Originally Posted by thechef
i think we had this problem on NOYZEEs car a few years ago and i think he just took a piece of alum tubing and stuck it down the filler neck making another vent which solved the problem, if i remember correctly
