fuel pump dead?
Old Oct 19, 2006 | 04:30 PM
01'WS6's Avatar
Default fuel pump dead?
Is it possible for a fuel pump to be completlely dead where you can not even hear it turn on? The car wont crank and its a factory pump. It turns over but there is no pressure in the rails at all and like i said u can not hear the pump turn on either. Also replaced the the relay and checked the fuses and those are good. Anything else it could be?
Old Oct 19, 2006 | 05:51 PM
GreaseMonkey83's Avatar
Im not 100% sure on this, but on most gm cars you can test the pump by putting 12 volts to a pin on the obd connector under the dash. If so, put 12 volts to that pin, then open the gas cap and put your ear over it and if you cant hear the pump run, then its probably bad. If you got a repair manual, it probably has steps to help you troubleshoot.
GOOD LUCK!! -Allen
Old Oct 19, 2006 | 09:53 PM
Juiced2000SS's Avatar
If you don't hear the pump prime, it's probably the pump. Check your fuses first, and do what was said above also to be sure.
