Walbro 255 pressure??
Old Oct 21, 2006 | 03:19 PM
SPRAYED 01's Avatar
Default Walbro 255 pressure??
Im running an inline walbro 255 pump with the hot wire kit. I have a gauge in the car and it always ran at 64-65psi and 61 under spray. One day it just drops down to about 48 around town and like 54 on the highway. Any ideas? Could the stock intake be bad?
Old Oct 21, 2006 | 10:05 PM
SPRAYED 01's Avatar
also on cold start it will have 65psi and then slowly go down to mid 40s. Any ideas???
Old Oct 22, 2006 | 08:30 AM
The Red WS.6's Avatar
When was the last time you changed your fuel filter?
Old Oct 22, 2006 | 09:26 PM
SPRAYED 01's Avatar
About 3k ago. I took it out and the fuel was clean and it wasnt clogged. I can still hear and feel the inline pump running. And can also hear the stocker kick on.
Old Oct 22, 2006 | 09:52 PM
Im having the same problem to a degree. I've got a pro charger and pressure is fine untill I get on the gas. It starts at 60-61 then will drop to 57-58 when Ive been sittin still in traffic. Today at 1/2 throttle @ 4,000 rpm it jumped from 60 to 50. I also have a racetronix intank. Im beginning to wonder if the stock fuel pressure regulator is going out. My car has been pro charged for 3 years now. Im going to try a check it tomorrow, I'll keep you posted. I'd like to know what is going on too.
Old Oct 22, 2006 | 10:05 PM
SPRAYED 01's Avatar
Where is the regulator on our cars? Is it part on the pump?
Old Oct 22, 2006 | 10:09 PM
Jake@EPP's Avatar
The regulator is in the bucket, it hooks right into the return line on the bucket. A 255 should stay 60psi depending on load, you arent too bad if it drops to 55 or so. Any more then that, i would start looking for the problem as it will make it go lean.
Old Oct 22, 2006 | 10:15 PM
SPRAYED 01's Avatar
If my stock intake was bad or even better it wasnt there, would the inline walbro be enought to keep me at 60-65. Im just trying to figure out which one of the pumps would have to be bad for my symptoms.
Old Oct 23, 2006 | 12:37 PM
Old Geezer's Avatar
Question ??
If the external, higher flowing pump, has to draw thru a pump that's capable of lesser volume, how does one expect the smaller pump to "keep up"???
Old Oct 23, 2006 | 04:19 PM
ArcticZ28's Avatar
Typical problem with the walbro's. Mine held great pressure until one day after driving for about an hour it dropped down to 40 at idle and then just started cutting out. Turns out it just burned up for no reason at all. I never let the gas go below 1/8th of a tank (which was only once) and it always stays above 1/4 regularly. It lasted about 1000 miles before I replaced it. A lot of people have had the same problems. The walbro's just suck,and good luck finding another one that isn't just a walbro pump in a different package. Unless you're wanting to spend $400 on an aeromotive pump the only route i've found is to just replace the walbro's when they take a **** like that. At least your car is still running though. Good luck.
Old Oct 24, 2006 | 09:50 PM
Are the racetronix brand a rebadged walbor?
Old Oct 24, 2006 | 10:31 PM
ArcticZ28's Avatar
Sure is.
Old Oct 25, 2006 | 08:36 PM
AWw crap!
Old Oct 26, 2006 | 08:37 PM
2002/Black/SS's Avatar
Originally Posted by ArcticZ28
Sure is.
AWw crap!
hahahahahhaha
what is the reason it has 63-64psi on a cold start but after i start driving for alittle it goes to 59-60, mine does it, whats the reason???
Old Oct 26, 2006 | 08:47 PM
SPRAYED 01's Avatar
Im just going to replace it and see what happens.
Old Oct 26, 2006 | 09:35 PM
Mine started out like that. It was perfect 60psi for 10k then it would dip to 58 after it warmed up. Then it started to drop just a tad, then to 60 to 55. Then from 60 to 50. Then From 60 to 48. This is under 8psi of boost. Now it starts at 58. Car is parked until probelm is solved. I think its the inline as Ive already got a racetronix intank installed. I bought the intank to take care of the problem, didn't fix it. But I think the inline is choking it off. sux...
Old Oct 26, 2006 | 09:40 PM
SPRAYED 01's Avatar
Keep us updated.
Old Oct 26, 2006 | 10:27 PM
ArcticZ28's Avatar
Originally Posted by 2002/Black/SS
hahahahahhaha
A lot of people are asking the same question.
Old Oct 26, 2006 | 11:07 PM
BigBenz's Avatar
very nice tip
ill never buy a walbro
