96# Injectors... Good for?
Old 10-22-2006, 12:29 PM
TrakDay's Avatar
Default 96# Injectors... Good for?
I have a set of 96# injectors I was planning on using with a Versafueler on an F1C Procharger setup. I changed my mind and will now be going TT and using BS3.
Anyways what kind of max HP level would I see out of the 96# injectors at 90% DC? rough estimates? Or should I plan on stepping up to 160# injectors? 1200+rwhp is the goal.
Thanks
Old 10-22-2006, 01:15 PM
Old Geezer's Avatar
Exclamation The 95's are..
not going to take you to the 1200RWHP.
The calcs show about 124PPH is going to be what you need.
I'd go w/ the 160's. Buy in a matched set, ONLY!!
Old 10-22-2006, 02:34 PM
TrakDay's Avatar
Yeah... I figured I would need the bigger injectors. well if anyone needs some 96# injectors PM me! haha
And yeah I will make sure they are matched. I will probably just order them from Stenod.
