Injector and FP regulator
Old Oct 26, 2006 | 05:57 PM
Armyman2445's Avatar
Default Injector and FP regulator
I found a good deal on a set of 42lb injectors but all i need are 36lb injectors. So with my fuel pressure regulator could I limit the 42lbers down to 36lbs
Old Oct 27, 2006 | 10:13 PM
SVC707's Avatar
you still need a tune so you car knows its running a different injector
Old Oct 30, 2006 | 10:52 AM
sonicbaloo's Avatar
You are going to need a tune for 30s or 42s. Run the 42lb at the correct FP and have the tune scaled for the 42lb injectors.
Chad
