aftermarket fuel rails??????????????????
im trying to put on some aftermarket fuel rails but cant keep the injectors from leaking. i pop them all in , push down on the rails while tightening the brackets and still they leak. please help.
yepp, and still a few of them leaked from the top as soon as i turned the key, and i tried taking them all out and putting it all back together several times, and tightening the rails down at slightly different angles
You might have cut an o-ring during the installation of the injector in the rail. If the o-ring is a size bigger or not lubed right then it will get cut. Double check that none were hurt.
Chad
Chad
