Walbro pump install information HERE!
Old 11-26-2006, 09:58 PM
Possible Scammer - Buyer Beware - Issues Unresolved
00ls1's Avatar
i wish someone had a write up like that on how to assemble a dual setup
00ls1 is offline
Old 11-28-2006, 11:09 AM
Lubricant's Avatar
A dual setup is pure custom work! Its hard to do a writeup on that..
Not many do it, and due to the diff gas tanks in the diff gen's or year f-bodys, its going to be a lot of writeups for a small num of people..
I would say, to get some smart friends together and make a weekend out of it..
All ya have to do, is make sure the pickups are in the gas, wire strap em up in place (since there is no real mounting method) and make sure your clamps are tight.
Lubricant is offline
Old 11-29-2006, 10:07 PM
00ls1's Avatar
the mounting thing is what has me worried
00ls1 is offline
Old 12-06-2006, 01:56 AM
Frost's Avatar
It just so happens on a day after your post....
It's not a writeup, but it's a small narrated photo-session, and I'm sure you will get the gist.
https://ls1tech.com/forums/fueling-injection/615108-my-twin-walbro-s-01-t-pics-schizz.html
Frost is offline
Old 02-20-2007, 01:07 PM
Lurius's Avatar
How long does this install take usually, excluding time to drop the tank? Im wanting to do this on my truck soon. I have the pump kit and am just waiting for a good day to do it. Today is in the 70's here in Texas and if this is 4-5 hours or less im all game!
-Lurius
Lurius is offline
Old 03-13-2007, 07:11 PM
LS1TECH Sponsor
Racetronix's Avatar
Racetronix, its dealers and most pump manufacturers do not recommend removing the sender in this fashion. It is best to remove, inspect and clean the tank before installing a new pump when possible.
Always refer to your GM factory service manual for proper procedures and safety warnings.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Racetronix is offline
Old 05-22-2007, 02:08 PM
Tough Mudder
Hilton's Avatar
Good information. I'm swapping in a Walbro intank this week. Thanks for writing it.
Hilton is offline
Old 05-27-2007, 12:36 PM
matthewjosh's Avatar
Thanks this really is gonna help me!!!!!!!
matthewjosh is offline
Old 06-09-2007, 10:01 AM
walwal63's Avatar
can you get to that area on a convertible?
walwal63 is offline
Old 06-19-2007, 09:13 PM
RagnZ's Avatar
i also need to know if you can get to the pump on a vert...
RagnZ is offline
Old 06-24-2007, 04:57 PM
Blackj98's Avatar
i am tryin to put a 255 in my 98 T/A....any help??? or email...to ljbx88@yahoo.com
thanks guys
Blackj98 is offline
Old 07-01-2007, 06:26 PM
  #32
tmcmillan5's Avatar
Question
Hi Nicolas, I have a 96 Buick Roadmaster tank,in my 68 chevelle,that must have had an LT1. Would I be doing the same setup you have discribed in your Sticky. My plan is for an LS1 conversion and I want to also ask what other fuel related items I could be mounting in this trunk setup I've shown in the pic below ie Filter/Regulator, fusses or Relays ?
Thanks, Tony
tmcmillan5 is offline
Old 08-04-2007, 02:21 PM
  #33
mellowyellow's Avatar
I am doing this Monday along with the Hotwire kit from Nasty Performance ...... Will update..
mellowyellow is offline
Old 12-09-2007, 11:35 AM
  #34
CALL911's Avatar
Originally Posted by Boodyrider
So Tuan, we need a writeup on the 98 install!!!!
I agree. Us guys with the 98 LS1's are left in the dark here.
CALL911 is offline
Old 01-28-2008, 06:59 PM
  #35
connexion2005's Avatar
If anyone is curious about where to cut the trap door at see my vid at:
www.ls1videohowto.com
Thanks!
connexion2005 is offline
Old 02-02-2008, 12:03 AM
  #36
Big Al's Avatar
Does anyone besides me wonder why GM used the jet set up and a fuel bucket to feed the pump and you just disregarded it? What happens when your tank gets low on fuel, or do you always keep it above 1/4 tank?
Al
2002 Z28 M6
Big Al is offline
Old 02-02-2008, 07:01 AM
  #37
Reject's Avatar
always keep it above 1/4. and honestly if you are letting it get that low you need to be slapped. that kills fuel pumps like no other. the heat they generate is cooled by the fuel, have it at the very least a 1/4 and begin looking for a gas station to fill it up.
Reject is offline
Old 02-02-2008, 02:42 PM
  #38
Al
2002 Z28 M6
Took a good look at it and there was not way that my Walbro was gonna fit. Gave it a shot and I've had no troubles for 40,000 miles and I've run it down to less than gallon in the tank a dozen times atleast. Maybe it wasn't as important as you thought because those numbers speak volumes to me...
Old 02-04-2008, 09:55 PM
  #39
OldskoolRcr's Avatar
The write up was for the 99, what about the 98? whats different in the location to cut for the pump, and the insatllation?
OldskoolRcr is offline
Old 02-05-2008, 09:54 AM
  #40
CALL911's Avatar
I'm with OldskoolRcr, what about the 98's?
CALL911 is offline
Quick Reply: Walbro pump install information HERE!
