-8 AN Rails? Were?
Old Nov 2, 2006 | 05:09 PM
Speed Density's Avatar
hashtagBMW
Default -8 AN Rails? Were?
Everywere im looking has -6. I need -8 and i guess im just not looking in the right place. Anybody point me in the right direction?
The rails are for a Victor E
Tony.
Old Nov 2, 2006 | 05:17 PM
Slowhawk's Avatar
LS1Tech Sponsor
Summit or Jegs has them.
Old Nov 2, 2006 | 05:18 PM
hashtagBMW
I have the EDL-3630 right now. But I half assed plumbed the car, so now im going to redo all of it. Starting with the back.
All I can find on Summit is 3/8s and thats -6 right?
Tony.
Old Nov 2, 2006 | 06:02 PM
ls1king000's Avatar
Summit should have a 3/8npt to -8 adapter
http://store.summitracing.com/egnsea...115+4294906747
Old Nov 2, 2006 | 06:05 PM
ls1king000's Avatar
Say if we wanted the drill/retap our 3/8 npt rails to a straight -8an, what thread would that be? 3/4-16 sae. I'm also a little confused about an thread. Can someone clarify? I know it stands for army/navy.
Old Nov 2, 2006 | 07:23 PM
andereck's Avatar
Its more than just a thread, A/N also includes a chamfer for the o-ring. You can puchase a tool that will drill, spotface and machine the chamfer but they're fairly expensive. Much more than the cost of a couple sets of rails.
Do you feel that the 3/8" pipe thread will limit you for 4 cylinders?
If you get a chance look inside the injector opening of a stock rail sometime. Factory rails will support over 700hp without modification. If you look inside the injector opening you will see what point I'm making.
Old Nov 2, 2006 | 11:43 PM
hashtagBMW
I just thought it would be easier to just run -8 for the whole system after my Y-Block.
But the -6an rails seem to be what most High power guys use.
Tony.
Old Nov 3, 2006 | 07:26 AM
V6 Bird's Avatar
I use the larger Mustang 5.0 rails. Aeromotives to be exact. They are a true -8an and I had to make mounting blocks for them to fit my intake. Not hard but if you arent any sort of fabricator dont bother.
Old Nov 4, 2006 | 06:12 AM
EPP's Avatar
EPP
Smile
Tony.
http://www.exoticperformanceplus.com....html?item=737 Bob
Old Nov 5, 2006 | 12:56 PM
2002/Black/SS's Avatar
Originally Posted by Exotic Performance Plus
are all aeromotive ls1 rails -8 fitting bob? like the ones u sell
Old Nov 5, 2006 | 06:52 PM
EPP's Avatar
EPP
Smile
As far as I have seen, they are. Bob
Old Nov 19, 2006 | 05:07 PM
1320 killer's Avatar
I have a set of aeromotive rails for my ls1 that are 5/8 they go for $196
Old Nov 19, 2006 | 05:37 PM
stevieturbo's Avatar
My aeromotive rails were -8
Old Nov 20, 2006 | 11:12 AM
Nasty N8's Avatar
Our rails with a 3/8"-8an is the same size and has seen 2150HP so I do not think anyone would run out anytime soon. Also -6 will supply over 800rwhp.
Nate
Old Nov 21, 2006 | 09:21 AM
Fire67's Avatar
Speed Density-
Just get a new set of Vic E rails. They're set up to fit exactly and the injector spacing is correct for your already set up manifold.
Those rails have a 9/16" i.d.... More than plenty to feed whatever your building.
If you're running -8an from the tank to the rails, you should have the rails plumbed in parallel with y-blocks. You can feed each rail with either -8an or -6an adapters from summit.
I personally fed each of my rails with -8an and plumbed -6an from the outlet of each rail to the pressure regulator.
Like Nate said, a -6an feed into each rail (coming from Y-block) will support 800rwhp forced induction style. So if your N/A or N20, they will support even more.
Old Nov 21, 2006 | 01:06 PM
Nasty N8's Avatar
I mentioned a single -6 will feed about 800rwhp. I run 2 Yed to the rails for our 1200hp setups.
