low fuel pressure with key on???
Old 11-06-2006, 08:48 PM
White Fire'99's Avatar
Default low fuel pressure with key on???
posting for a friend.
it has 8psi then bleeds down to 0 and kind of sputters fuel/air out of the schraider. this is when key is turned on for pump to prime. pressure seems fine when car is running. but this make it hard to start.
bad pump?
Old 11-19-2006, 02:34 PM
shoemike's Avatar
check the connection from the pump to the fuel line in the tank. i had low psi and my
connection in the tank was jacked up.
Old 01-07-2007, 12:22 PM
roadtrip120's Avatar
any update??
I am having the same problem,on my LS1 but with 30 psi when the key is turned on.
Did you find the problem or fix??
I was going to replace the pump??
Any ideas, regulator, wiring??
Old 01-07-2007, 07:28 PM
Disturbed Bird's Avatar
samething happened to me but at a red light and it died on me check it out and it was cuased by a blown fuse. but im running a aftermartket fuel system. what r u running?
