stock fuel line limit?
Old Nov 16, 2006 | 08:54 AM
pushinfreight's Avatar
Default stock fuel line limit?
What is the limit of the stock fuel lines? My project will have a 408 that should put down about 500/500 on the motor. Now I plan on spraying up to a 300 in total on the n02. Will the stock fuel lines from the tank to the fuel rails support this? This will be a dry setup.
Old Nov 16, 2006 | 12:18 PM
MIGHTYMOUSE's Avatar
it used to be 600rw, but have seen some with enough fuel pressure go 700rw.. you need to overdue the pump set up to push through the line.
Old Nov 16, 2006 | 12:31 PM
I have an intank 255l walbro, 42 lb injectors, a voltage booster, boost-a-pump and speed inc fuel rails. Right now I see a constant 62 lb for fuel pressure. My duty cycle on the injectors is 65% right now.
Old Nov 16, 2006 | 01:26 PM
yomama's Avatar
Me2 ,
We have found that 700 horse is where the volume cant keep up. But it realy depends on the BSFC of the motor.
Ryan
Old Nov 16, 2006 | 01:38 PM
Originally Posted by yomama
Me2 ,
Ryan
So can we go with a larger hard line for the feed line? I know you can go with fuel hose but not sure as have seen issues with degrading of the inside of the braded fuel lines.
Old Nov 16, 2006 | 03:10 PM
MiaSSmaro98's Avatar
guys if i buy rails can i install them factory style with no regulator?
Old Nov 16, 2006 | 03:15 PM
2002/Black/SS's Avatar
ya, the speed inc rails, with thier install kit, is all u need to install them, and it dosent use a regulater
Old Nov 16, 2006 | 03:26 PM
hey wassup still missing parts?well i relocated my alternator and i dont think they will fit let see if someone postes some pics
Old Nov 16, 2006 | 03:56 PM
lets stay on topic, fuel lines from the tank to the rails
Old Nov 16, 2006 | 03:58 PM
qqwqeqwrqwqtq's Avatar
We've made 995rwhp through a T400 trans with the stock fuel line/filter and dual walbros.
Old Nov 16, 2006 | 04:04 PM
Omg That Crazy
Old Nov 16, 2006 | 09:01 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
That makes me feel better.
Old Nov 17, 2006 | 07:30 AM
Now do you feel that was because of the fuel pressure that you were runing? If so what was the fuel pressure?
Old Nov 17, 2006 | 07:46 AM
gator's 99TA's Avatar
call speed inc ryan. sounds like they have experience with this.
i would personaly just run new lines from the tank up.
Old Nov 17, 2006 | 10:44 AM
thats impressive, even if you were running the voltage up to the pumps.
there are online calculators for that will tell you fuel speed through the line at a given line size, fuel pressure, and horsepower
i used this to determine that for 'normal' fuel speeds i would be safe with a single -8 line for anything i would ever do with the car.
i dont know the drawbacks of having fuel moving so quickly across a distance but assume that there are some
Old Nov 17, 2006 | 11:54 AM
so from what I can tell it is all about how much fuel pressure you can produce. With a dual intank setup it seems that there will be enough pressure to support 800 rw on a nitrous setup.
So if you from a single to a dual setup is there a disadvantage of having say a 255l and a 355l in the tank together?
Old Nov 18, 2006 | 12:16 AM
Pumps were just running off vehicle voltage, no boost-a-pump.
I'm not sure what drawbacks there would be but the car has ran consistently well since it was finished.
Old Nov 18, 2006 | 02:38 PM
now thats amazing
Old Nov 29, 2006 | 01:07 AM
EGash's Avatar
I was wondering this too. If you're running twin pumps, do the flow rates of the pumps meed to match?
