are lt1 and ls1 injectors the same?
Old Dec 18, 2006 | 09:58 AM
trouse40's Avatar
Default are lt1 and ls1 injectors the same?
i bought some mototron 60's for my lt1 and they look very diffrent than my stockers. but could not find a part # diff between lt and ls.
Old Dec 19, 2006 | 07:41 AM
jldak318's Avatar
they are the same plug and such but the only thing is that if you have a lt1 injector that is rated at 30lbs/hr and you put them in a ls1 they will act as 34lb/hr injectors because of fuel pressure. but yes the ones you have will work fine if they are for either application.
