Need fuel system suggestions
Ok, stock engine with cam, supercharger, blah blah blah.
I need recommendations for a decently priced setup from the tank to the intake manifold. I'm running a returnless system.
I have the following already:
Walbro 340m in-tank (not installed)
Walbro 342s in-tank
T-Rex 255lph in-line
Mototron 60# injectors with a custom EFILive OS.
Casper's fuel pump hotwire kit
I plan on installing dual in-tanks and ditching the in-line, and gutting the stock FPR to run a boost-referenced APFR per Mike Brown's recommendation.
Here's what I'm looking for:
Boost-referenced AFPR
Whatever lines from the stock fuel pump assembly to the engine, I'm guessing AN Fittings
Fuel filter
Fuel rails w/ install kit and adapters for everything listed above
I'm not looking for a "power goal", I'm looking for run a more efficient fuel system and run the AFPR so I quite deadheading my fuel pump now. The car sees 60-63psi at idle and cruising, 58psi under boost.
My budget for everything is probably $500 and hopefully less since I have a good chunk of fuel parts already.
Walbro 342s in-tank
Fuel filter
I know with all of the custom and non-custom applications, someone out there (sponsor or private owner) can give me some info. This site is better than that.
