Fuel Problem? Cutting out past 5K. help
Old Dec 27, 2006 | 12:19 AM
TransAm8723's Avatar
Default Fuel Problem? Cutting out past 5K. help
I guess this is the right section, if not, feel free to move. Pretty much lately my car runs great around town, even when driven rough. But when going WOT, car seems to not want to go past 5K-ish, not violent or "choppy" like fuel cut, but it just won't go past it, and my SES light comes on (still drives fine after). After about 10 minutes, the SES light goes off, still drives fine. I asked around and people said it was probably my fuel filter, so I changed that today, and no luck. Since it idles fine and drives fine, I figured it was ok to rule out plugs and wires. I don't want to break the bank fixing this, so do you guys have any experience or ideas on what this could be? I actually have a 255 Walbro sitting in my room, but i doubt it's the fuel pump. I'd hate to have the 12 second TA not running to its full potential (136K miles though ). Thanks.
Jeremy
Old Dec 27, 2006 | 08:08 AM
Frost's Avatar
So why not just scan and figure out why the SES light is on?
Old Dec 27, 2006 | 08:46 AM
Old Geezer's Avatar
Check the Fp with a gauge placed under the wiper arm.
Go to WFO, and see what the psi is...Should tell you rather quickly, if the system is at fault..
Old Dec 27, 2006 | 10:10 AM
thanks
Old Dec 27, 2006 | 11:37 AM
dschmittie1's Avatar
I saw a set of bad plugs and wires in my buddies 98 Z that idle and drove fine but as soon as you stompted on it it fell on it's face. Pulled the plugs and the electrodes were basicly gone. New plugs and it drove like new. I thought it was fuel related at first too. But I would check fuel preasure and pull a plug or too out. also scanning the code would be good too.
Old Dec 28, 2006 | 01:12 PM
dschmittie1, thanks. Will definitely check plugs. I figured it wasn't plugs since it idled fine.
Old Dec 28, 2006 | 03:20 PM
Frost's Avatar
Plugs are a likely culprit for what you describe.... does the SES light flash while the problem is going on? could be misfire codes and could be pointing to the same thing.
Old Dec 28, 2006 | 08:19 PM
z28drag's Avatar
scan the car,
Old Dec 29, 2006 | 11:50 AM
going to get plugs today, hopefully that will fix it. It's been a while since they were changed, so that's probably it.
Old Dec 31, 2006 | 01:02 AM
BLKNRDPREDATOR2001's Avatar
i had the same problem on my 01 WS6, at WOT it would run sluggish and the SES light would start blinking. I had a friend put a fuel pressure gauge at the fuel rail's schrader valve and surely it was the fuel pump. I thought my spark plugs and wires were bad, my injectors, coil packs he checked all that before with the hypertune and everything was fine til he checked the fuel pressure. Check your fuel pressure i bet your fuel pump is getting worn out.
