carb style throttle body?
Does anyone make a 1-hole or 4-hole throttle body which will interface with the gm ls1 computer so a 14" air cleaner and GMPP carb manifold can be used?
http://www.holley.com/types/Universa...l%20Billet.asp
I believe those are both using GM TPS sensors and IAC motors.
The first one (the 4150 flange PN 9900-171) is correct to bolt to the GMPP intake manifold (assuming the GMPP catalog isn't lying when it says it accepts a 4150 carb.
