so what's the difference in all the injectors?
what I'm looking for are 42lb injectors that are VERY close to the same flow rate since I will be spraying a pretty decent size dry shot soon.
Variations of that magnitude are EXACTLY why one should purchase injs in flow matched sets ONLY...[The "family sedan" can tolerate the mismatch, the hotrod cannot.]
Case in point: Just flow matched a set of 160's, for a 10.5 SBC.. I went thru 24 injs to get 8 that were close enuf to use..
I think that is why their prices are a little lower than most...so far so good though. Comes with a flow sheet, and all of the injectors are numbered so you know which ones flowed what. Trending Topics
I think that is why their prices are a little lower than most...so far so good though. Comes with a flow sheet, and all of the injectors are numbered so you know which ones flowed what.The Best V8 Stories One Small Block at Time
http://www.deatschwerks.com/injectorinfo.htm
Looks like they use core injectors, so that would explain why they look used (they are).
As for the difference among all 8 injectors in my particular set:
Static:
100% duty cycle (43.5 psi) - 0.3%
Highest flow was 314 cc/min, lowest was 312 cc/min.
Dynamic:
75% duty cycle (43.5 psi) - 1.4%
Highest flow was 249 cc/min, lowest was 242 cc/min
Since they were numbered, I put the highest flowing ones in the back of the intake manifold, and went forward from there so the lowest flowing injectors were at the front.
