walbro 255 direct fit fuel pump?
Wow, that is a long time. Everything else I've read has had all positive feedback from them. Thanks for the info though. Personally, I'm in Iraq so they could take another 5 months and it wouldn't affect me, but if I were back home it wouldn't be acceptable. Maybe on a GP with a lead of how many orders are coming they would be more pro-active for fear of more negative feeback. I think it's worth looking into to save $40+ as long as it's a quality kit. Did you ever find out the reason and get compensated for the delay?
N4cer you are correct, we ran out of one of the connectors for the harness and it took them 4 weeeks to ship it to us, it was really out of our hands. Hot wire kits are now in stock, in quanity, and there are no delays. I appreciate the professional tone of your post. That is just too long to wait I agree. If I can do something to make it up to you say the word.
Mike
Mike
Originally Posted by 2001z
make sure you get a hot wire kit or this all for nothing !
Originally Posted by trans2000am
do you really need this kit? I thought it included everything thats why its called a direct fit kit? maybe I wrong ,sponsors any info on this?
Research putting more voltage to the pump on it's own merits. As far as the pump is concerned, if yours is on the way out and you need a pump, you will operate as normal without the hotwire deal. I didn't use one and my car runs fine. I don't know about what will happen if/when I start demanding more fuel, but make sure you know the potential downsides of bumping voltage as well.
Just to add. Increasing voltage to over 13.8 by using a booster type device will for sure lower the life of the pump. The hot wire kit is to stop the voltage drop that happens with the stock wire harness when the extra load from the new pump is added. Low voltage willl actually kill the pump faster than high voltage will according to Walbro
Mike
Mike
#33
so you do need the hot wire kit? for say a boost application.why dont they tell you this things,oh well guess thats another 100 bucks on parts i didnt think i needed.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#35
no one mentioned this to me either when i bought this same pump.
don't you guys think this is important? I mean we are trusting you guys with our cars.
you tell us you have a high volume pump but then you skip the fact that it needs this hot wire kit to function at full capacity?
Does that make any sense?
#36
What are you guys talking about? It's commonly accepted that to get the most from an aftermarket fuel pump you need to upgrade the wiring. Just like if you go higher hp, you need more fuel system. Same thing. You want to put out more power, you need more coming in.
This is not new information. And it's not any company's job to make sure you understand basics like this. Actually their fuel pump has more stuff with it than any other fuel pump. So where's the problem?
It works fine just the way it is. Please understand simple English: You DO NOT NEED the wiring harness for the fuel pump to work. So NO, you don't NEED it. But you need it if you want the pump to function at its best, last the longest it can, and to get your best dollar's worth out of it. Or you can make your own wiring upgrade for half the price, but it'll not look as good nor be as easy to install.
#37
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
#38
This little fact about the hotwire kit isn't mentioned anywhere except by word of mouth here on ls-1 tech.
A commonly accepted fact for me at least, simple minded person that I am, is knowing you should run colder plugs for nitrous.
#39
I actually knew about it from my local F-body owning friends who have already modded their cars. Not from here. But if you read around the fueling section here, you'll see it also. Haven't you noticed you hear the word "Racetronix" a lot? Well, this is why. The wiring.
