fast injectors
Old Feb 11, 2007 | 08:06 PM
LS1s R US's Avatar
Default fast injectors
What is the fuel pressure fast fuel injectors are rated at!There site sucks if they are rated lower than the 58psi a LS1 has it will be bigger?And the tune will be alittle different!
Old Feb 12, 2007 | 11:13 PM
Nasty N8's Avatar
Most all injectors are rated at 2 bar which is 43psi Ls1 is at 3 bar 58PSI just a percentage difference.
Nate
Old Feb 19, 2007 | 11:12 AM
LS1s R US's Avatar
I talked to fast with a 45 psi rating the 36injector, they said the fast 36 at 58psi would be 46.4 psi injector at 58 psi!Does this sound right to ya'll!They done all the calculating of the size!Any thoughts!
Old Feb 19, 2007 | 02:58 PM
Old Geezer's Avatar
Talking
New FP divided by old. Then the sq root of that calc, times the old flow rate, gives you the new rate at the new pressure..
BTW, most injs are rated by thier mfgr at 3 bars.
2 bars is not 43.5, it's 29.4...
