Stock tank W/Comp sump fuel line routing.
I have a stock tank with a Comp Engineering sump. I am going to run an Weldon inline pump and I'd like to use both bungs on the sump to feed the weldon pump, kinda like a "Y" 2 into 1 system. Has anybody done this before? If so does anybody have pics?
On the return side I'd like to run a 90* AN fitting on the top of the tank, then attach a SS 1/2" tube to be put inside the tank as the return line. Is there a certain direction that the return tube should be dumping gas into the tank, towards the sump or away from the sump?
Any reccomindations are greatly appreciated.
you could use a Y if you want to, just get a good Y russel makes good ones that are a lot cheaper than aeromotive, I have one in the 1/2 inch version that I put 8 an fitting into to split it off to my fuel rails. if your putting a return back into the tank have it directed away from the sump, if you have it going toward it you could get air in the system from it.
you can run like 2 -8 lines from the tank to the Y and a 12 out, on mine I just have a 12 line coming right out of the tank
![](http://www.streetlethal.net/EFI/IMG_1751.JPG)
