Where to get fittings to connect to factory lines?
I am going to be using my stock lines for my fuel system. I plan on using the stock supply line for the feed, and the stock EVAP line for the return. Where can I get female fittings that will connect to the stock hard line that comes up into the engine bay and converts the 3/8" feed line to a -6AN fitting, and where can I get a fitting that will do the same for the 5/16" EVAP/ new return line?
