10AN Braided Teflon line needed in bulk
I've been searching for 2 days and I can not find anywhere I can buy 10AN SS braided line with a teflon jacket. I prefer to buy 20 ft section, and 8AN 20 ft section and 6AN 15 ft section. I know that full PTFE requires special crimping tool, but does SS braided rubber with teflon jacket? Ie. Can the teflon be pushed back a little and standard AN tools be used?
Harris Speed Works & Aeroquip seem to only go up to 8AN.
Addressing a fuel pump delivery issue and getting rid of all the smelly lines. 1000 rwhp is on the horizon and I suspect a 10AN feed will be a requirement.
TIA
TIA
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Earls makes a new Teflon line....used by Nascar VERY expensive...I did my car in it 1200.00 for the fuel lines will support 1500 HP. It is Kevlar covered lightweight teflon hose. Ends can only be crimped. I had Earls Indy do the work for me very reasonable....great to work with ....comes in sizes to -16. The best....NO Mor Gas Smel!!!!!!
Tom Ulrich
Tom Ulrich
Since no sponsors on here have replied, i'll post up a couple of places i've found. Maybe you can contact one of thses places. Check out the G-Line hose. It looks like you can use crimp or re-usable fittings.
http://www.hosenow.com/goodrdg.htm
http://www.amfmotorsports.com/update....tech.info.pdf
I have got 50+ feet of it in my garage? Let me know if you me to get you some. You are talking about the teflon with the SS braid on the outside right. I hate smelly lines also. I looked for a while and now I can get all you need. Good price to. Thanks
8an should feed 1000+ all day long...10an for 1300RWHP+ and 12 should be good for around 1600+RWHP. Those are only recommendation though
I've seen 10AN on 2000+ horsepower setups though...
What could you possibly use 50ft of 10an for? You plumb race cars for a living?
What could you possibly use 50ft of 10an for? You plumb race cars for a living?[/QUOTE]
I have the hook up on this hose. I actually bought 50ft of -4,-8,-10 for under 200 bones. Just one hell of a deal. I will always need more for other projects.
