What size/brand of injectors for 700+ FWHP?
depends on what you plan to do to make that power. Also depends on fuel pressure vs manifold pressure. That differential vs power will be able to tell you what you need. My buddy's vette has 60#ers (@43.5 psi) on it with 80 psi of rail pressure it hits 80% duty cycle at 5500 rpm and 630 rwhp with 15 psi of boost and 11.7:1 AFR.
By the way, are you referring to these:
135-INJ-L107FM-8
Siemens/Mototron Deka 4 Flow-Matched 60# Style Fuel Injectors (Set of 8)
-Static flow @ 60lb/hr @ 43.5PSI = 630cc/hr (sold as 65lb/hr by some vendors)
-Coil Resistance: 12 Ohms / High Impedance / High-Z (No ECM driver modifications required)
-Gain: 0.11ms/mg, Offset: 0.055ms, Turn on time: 1.14ms @ 14VDC, Turn off time: 0.85ms @ 600KPa
-Dynamically flowed and grouped to within 1% tolerance using Racetronix custom injector flow bench
http://thunderracing.com/catalog/?ac...vid=3&pcid=163
135-INJ-L107FM-8
Originally Posted by Dragaholic
Did I post the ones that you guys are referring to? If so, what kind of power do they support naturally aspirated?
Originally Posted by Urban Legend
Not to hijack this thread or anything. But what is the biggest injector that can be ran with the stock computer?
http://www.rceng.com/prices.htm
I just ordered 2 sets from A&A
