Flow rate on Lucas 32lb injectors
Hey guys I did a search in a few different sections but came up empty. First off do all the LS1 cars share the same fuel pressures? I have been reading and If I use a 30lb SVO injector on my 2000 Vette beacause of my fuel pressure it really puts out 36lbs. Now will that be the same with all injectors? The root question is will 32lb Lucas injectors really push out 38lb of fuel? I have asked around a bit and know one seems to know for sure. Any of you guys know? Thanks, Patrick
