bigger injectors = worse gas mileage?
i have a v6 as it says in the signature and i was wondering if i got new and more powerful injectors if it would murder my gas mileage or not
LS1TECH Sponsor
Properly tuned & sized within reason of expected actual HP, you should see no difference. If you go way oversized, atomization at low speed will suffer & possibly reduce your mileage.
Size them for for the true power output of the engine & do not think big injectors will make more power.... injectors do not make power, they only support the power that the engine can actually make.
