What size fuel line disconnect tool ?
If you're looking to disconnect the (3) lines at the top of your fuel bucket - All you really need is a pair of needle nose pliers.
I have all the sizes of disconnect tools and trying to get them in there was more trouble than it was worth - so i used pliers to squeeze in locking tabs and lines pull right off.
If you're set on using the tool - you will need the 3/8 for two of the lines, and I think the 5/16 will work on the 3rd...
