Want to upgrade dont know much?
Thank you
Bigger fuel rails - Add a nice bling also
Boost a pump - Add extra volts to the pump
Bigger injectors - If the ones you have go over 80% duty cycle get a larger set.
A "hotwire kit" is a plug n play wiring for the fuel pump, they are heavy duty(bigger wire and better metals than the factoy wiring) and usually include a connector for a boost a pump so if you want to use one then you don't have splice the wires. GOOD INVESTMENT. Ordering mine next week from Full Throttle. Their fuel kit w/ walboro pump is a complete drop in, no mods needed to fit and it's only $239 for the hotwire and pump. Hope this helps Nick W.
http://www.nastyperformance.com/FuelSystems.html
Thanks Nate
