How do you make a fuel cutoff switch?
You could hook a switch in series with the fuel pump power line. You could tap into it where it goes into the fuse box.
you can just cut the fuel pump wire and put in a relay to a switch in the car or a switch under the hood or in the rear wheel well area with a big amp switch externally and no relay.
