i need the best injectors
Old Feb 23, 2003 | 12:03 AM
WS7-PROJECT's Avatar
Default i need the best injectors
hey whats going on i need some advised on injectors. i have a 97 chevy camaro LT4, im running 15psi on a ATI procharger. the cam that im runnig is isky custom grind 225/224 560/580 in-ex on a 113 on a 165 rocker. afr stage 2 heads 195cc LT4 2.02 heads. rev limit 7200 rpm, shift poit 7000.
what would be the best injectors for this set up. i was looking at the accel 42 lbs. what do you guys reccomed.
thaks.......... <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Feb 23, 2003 | 02:37 AM
MIGHTYMOUSE's Avatar
Default Re: i need the best injectors
yes 42s may make it to that goal, what fuel pressure are you running and what is your fuel pump situation?
Old Feb 24, 2003 | 08:41 PM
CoopDog's Avatar
Also, have you checked at www.lt1tech? There seem to be some knowledgeable guys over there as well, specializing in the LT1's.
