injectors size?
Old Feb 23, 2003 | 11:50 PM
viper killer's Avatar
Default injectors size?
what is the stock injectors size on the LS1 engine.
Old Feb 24, 2003 | 09:18 AM
MIGHTYMOUSE's Avatar
Default Re: injectors size?
what year? a 98 is 28.6#
Old Feb 24, 2003 | 04:05 PM
thank u .
and yes its 98 camaro Z28 V8.
Old Feb 25, 2003 | 04:58 PM
What is the limit of the stock injectors .
Old Feb 27, 2003 | 01:02 PM
Doc99SSx's Avatar
I'm not sure what you mean by limit, but if you are referring to HP, 28.6#/hr injectors at 80% duty cycle would handle about 400 flywheel HP. At 100% duty cycle, you would be at about 500 flywheel HP. This is gotten by using 0.45 for the BSCF value for an LS1 engine.
Old Mar 3, 2003 | 10:46 PM
oh they cane handle up2 400 rhp with 80% ok so what abaut the fuel bumb.what is the limite of the fuel bumb.
Old Mar 16, 2003 | 04:32 PM
WMSuperSport's Avatar
I think you mean fuel Pump. It has about the same limits as your injectors, around 400 RWHP.
